1 - 2 of 2 Posts
G'day All,
Got the old girl back together today, and took her for a spin.
Replaced 2 boots (cvman), front wheel bearings (girlracersrock), front A arm bushings (EPI) and all 3 gearcase fluids (Polaris).
From an Aussie point of view, this forum has been great because we don't have any aftermarket spare parts for Polaris over here.
So the question is:
How far do I get into it with the clutch?
I mean, it's working and everything, but has probably never seen a service or new belt.
It slips a fair bit on take off, it's better if you move on with the throttle a bit.
Should I just throw a new belt on, or should I clean or service it at the same time?
Is there a service kit for these?
I've seen some guys on these forums really get into it about this topic, going all out with later model units etc.
I also see EPI has a new clutch set, complete with belt.
I havent pulled the cover off yet, so don't know if it's a Team secondary or whatever. It has EBS on the cover.
I'm fairly handy, and have a fair few tools, but I must say that the pics and proceedures in the manual look fairly daunting.
I've thought about just spraying it out with brake cleaner and putting a new belt on.
Would love some advice from the experts.
well not an expert, but pick up a new belt from polaris, check the drive and driven clutches for wear, also wouldn't hurt to add a high altitude clutch kit for stock tires(unless your tires r bigger than stock). That would really wake it up.
1 - 2 of 2 Posts
