I should have asked this a minute ago and just thought about it - I was trying to get the 2000 335 in gear last night, and it was tough moving it through the gear ranges. When I put it in low range it was tough to get back to neutral or any other gear. I finally did get it back.
Is there a good way to smooth this out so it shifts much smoother?
Is that while it's running? If so you likely have a clutch issue or maybe fast idle. If it is difficult to shift while not running, then it's likely an issue with shift linkage or internal transmission problem.
It was idling - and it doesn't idle too fast. Seems like it's running in the idle range it should be.
The shift lever is supposed to have oil inside. Make sure the boot isnt torn and check the oil.
Okay. A visual inspection last night showed there were no boot cracks. I'll check and see how the oil level is in it probably Saturday. I appreciate the help!
