my fourwheeler will not go into gear. the shifter will move into gear but the four wheeler wont engage. is it the belt or the clutch or what is it?
I would start by pulling the belt/clutch cover and see what is (or isn't) happening there first.
i figured it out the belt was shredded i guess i got water in there. but now the four wheeler will not crank by the start button or by pullint it off i had it idlin and i reved it up and it backfired and shut down and wont crank back up
Welcome to the board!:med:
Sometimes when these machines back fire it breaks the woodruff key that holds the flywheel in place. That is what does your timing.
