1 - 10 of 10 Posts
I got my first polaris it seems to bee a good quad but it only runs with the choke on. It will run without it but wants to bog out bout wot it's fine. I got a rebuild kit for the carb off of eBay with no change. Intake gasket or boor maybe? It's pissin me off I wanna go riding!!!
Check the boot see if its cracked and also verify you have good fuel flow to the carb.
Ok I'll pull it off tomorrow and check it out you can see it has small cracks in it but no big ones that go all the way threw. I can only see the top side someone took the air box out :(
does it have an air box now.....if not that may be your problem..they run funky with out one
well that may be the problem there...I had an issue when I cleaned my air filter..was running shitty....so back tracked..my air box cover was not on right..i fixed it an ran like new again...why it doe that I dont know....
Yeah no airbox with a K&N you are going to be running Hella lean.
Discussion Starter · #8 ·
Like it's sucking to much air so it runs lean so u have to run with the choke on making it richer? That's a good idea man I'm gonna try to maybe tape like half the filter til I can find the right air box. I've had a lot of other atvs and bikes but never a polaris. Any pd service manuals floating around here?
look for an air box on ebay....taping it wont help..the filter is pleated....your risking burnt vales or piston
1 - 10 of 10 Posts
