I just picked up a 2000 Explorer 250 4 by 4 for $100. Cosmetically is in nice condition been sitting for 4 years. The guy said that he broke the front sproket. I cant figure out, but seams transmission is stuck in forward hi. Possible the shaft hat holds front sprocket broke off, but no sure. I cant move the shift control at all. I cant turn the front sprocket shaft either. Any thoughts?
Not sure I'm following what you have going. I got my Xplorer after it sat quite a while and had to pull apart the box at the shifter handle (right side under gas tank), it was all frozen up. Some cleaning and lubing and I got mine working. It's floppy and 4 low can be a pain but it works. Might try starting there if it won't shift at all.
