i have a sportsman 335 the reverse light stays on constantly. when in unplug the speedo it deactivates the reverse limiter. the speedo only shows hours and miles but does not show the mph but the awd works. any ideas about the reverse light and the speedo.
Discussion Starter #2
also as a second note when i bleed the brakes the rear one bled the front left did but the right had no fluid or air going to it any ideas?
With the electrical problem I'd start looking at the reverse override circuit and the reverse light switch. The bleeder on the caliper is probably packed with dirt/mud. Remove it from the caliper and clean the bleeder out before bleeding it again.
brand new start/override switch. did not know i had a reverse light switch. unplugged the switch on tranny and light still stays on.
