I just bought a 2000 Polaris sportsman 500 for $900 being told it needed a starter. I figured it needed more than that as soon as I turned the key to the on position and immediately noticed no neutral light oil temp light speedo backlight or any of that sort. After testing some wires I found that I do have constant power at the ignition switch( dual solid red wires) and I have switched power ( dual red/black wires) and from what I've read I believe it to be the circuit breakers in the bags. Problem is after removing the front rack, radiator, and searching with a test light I can not find any of the breakers or any any fuses. Could anyone give me some photographic proof or a wiring diagram showing the circuit breaker locations. Thanks in advance:cowboy:
