I have replaced the battery, lights come on. The starter begins to engage but won't stay engaged and you can hear the starter running. How do you dismantle the starter from the pull rope casing? Please help, frustrated!!!
New Battery? I have seen low voltage do that same thing.. Also check your bendix drive, you will have to pull the pull starter side cover off to access it. The bendix is what you are hearing engage and disengage. Bendix drive is a fairly common problem.
welcome to the board!
