Picked up a scrambler 500 to fix up for the kids. I'm chasing the elusive AWD not working problem!!
Everything seems to check out and work mechanically, so now I'm working back through the electrical diagram. Basically I have no power coming into the AWD switch at all. when I jumper 12v to the Gr/w wire for the awd everything works, Where does this get its source power from the ignition switch or the on/off/start switch?
Also n the back of the ignition theres 4 terminals I have power coming into the switch but when I turn everything on theres only power coming out of the starter wires, the middle 2 terminals have no power exiting the switch. Is this a faulty ignition switch ?
Thanks!!
Thanks!!
