Hey y'all I've got a few questions on some electrical problems I'm havin with my 2000 sportsman 500 4x4. I knew there was something electrically wrong as soon as I turned the key when I was at the guys house looking at this atv. Turn the key no neutral light, speedo backlight, headlights, nothing. So I got a brand new advance AGM glass may type battery, new starter solenoid and new wires for the hot to and from the solenoid and new ground to the starter and battery. I don't own a multi-meter but I do have a test light, so at the electrical I went. I do have power at the ignition constant dbl red wires and switched dbl red/blk wires. I also have switched power at the kill switch on the led handlebar dbl red/blk again. But none at the red wire going to the cdi I've noticed. I know these atvs have a lot of problems with the "sealed" breakers not being so well sealed in the little black bags, but have only been able to find one zip-tied under the seat and I do have constant power in and out of the one. I've read on multiple forums that there should be 2 more under the front plastics near the radiator. I have yet to find these 2 after removing all but the front plastics. Any help is greatly appreciated
