1 - 1 of 1 Posts
Hi all I have a 2000 sportsman 500 with a blown motor. I have a 06 sportsman h.o. 500 motor that I wanted to swap it with. Have the motor on the 06 no carb or exhaust. Both are carb motors. I know the carb, intake, exhaust and electronics are different.
1. Do I need to change the jet on the smaller carb so it doesn't run lean?
2. How hard is it to change the electronics to the newer cdi? I am planning on using the old electronics but if the newer one is better and easy to do than I might change over.
3. Any tips are advice are appericated. Wife says I need all the help I can get.
Thanks all.
1 - 1 of 1 Posts
