1 - 8 of 8 Posts
Hello everyone ,
I have a 2000 sportsman 500 that while cruising the speedo and headlamp would just go out. When you start to slow down it all returns to normal. Can anyone plaese help me get to the bottom of this mystery.
Thank you
Born to hunt
Forced to Work
I found a common hot wire that is shared form the speedo/headlamp/and ignition switch. I in the process of tracking the wires and connections.
It might be bad ignition switch?
Ill let you know
try checking your circuit breakers
Discussion Starter · #8 ·
It only happens while the bike is traveling at around 35 . When you let off the gas and start slowing down everything pops right back on. It dose not happen while idling or when you are traveling under 25 mph. What circuit breakers and where are they located ???
1 - 8 of 8 Posts
