My right front disk is wet with oil and a puddle has formed inside the rim...inner hub seal?...is this a "do at home" project?...could this have anything to do with my front hubs not "unlocking" unless I back-up?...Thanks for any input!
First, welcome to the board!
It is so dirty I could not tell...although I coule see how it was "spun" out from the center...I have had a brake fluid leak I could not find but the brake fluid seems to be up as was the hub level...of course now that I am watching it it has not done it....?
does it smell like brake fluid? I doubt it's brake fluid if your brakes still work fine, it just takes a little caliper leak to totally loose all your brakes. probably hub oil.
