My sportsman 500 started overheating on my last ride, the fan is running & the radiator is free of any mud or debris. Does this model have a water pump that could go bad or any other suggestions on a fix
How old is the fluid in the radiator? If it is several years you may have clogged ports inside the radiator and will need to remove it and take it to a radiator shop and have them clean it out.Thanks I will take the shroud off & check it & I've never changed the fluid. I will try that also.
