any one have any luck tapping out the screws that hold the plastic cap on , I have broke two on one side and one the other , and now the one with two missing is leaking .
when they broke off did it break off in the hub or was any remaining out of the hub...if any is out of the threads on the hub try a vise grip..it they broke off inside...you may want to try a left rotational drill bit...and see if you can back it out....if i remember right the screw is sort small and I think a ez out may be hard....
Center punch and left hand drill bit would probably be your only hope. If that don't work, you'll likely have to drill them completely out and rethread to a larger size or find used hubs on ebay.
