I have 2000 polaris trail boss 325 and everything work but the transmission stars grinding when i shift into drive and also it goes from drive to neutral
What do i do
It's supposed to go from drive to neutral, but if you mean it jumps from forward to neutral unless you hold it in forward, then the problem is either shifter linkage needing to be adjusted or an internal transmission problem.
