1 - 2 of 2 Posts
Doesn't have all the power it should, leaks a little fuel out of the bottom of the bowl (where the tube hooks up to it). Checked the spark plug it was fine and took the carb apart and look like it was being blocked off by the choke maybe? I'm not too good on carbs, any one know what it is that's in the way?
Float needle is sticking or possible time for needle and seat replacement. While you are doing that remove pilot jets.etc and clean all parts. Remove the diaphram in the top of the carb before spraying carb cleaner on it.
1 - 2 of 2 Posts
