Went out to plow today, and went to back up. Then when I went to pull forward I couldn't get the shifter out of reverse. Finally parked it.
Doing some digging found it could be:
-Water frozen up in shift mechanism
-Sometimes Low and Reverse will go in together, there should be a way to pop it out of low and get it working.
When someone says "shifter case" is that the box the shifter itself goes into?
