Hello I have a 325 magnum with a 5 wire rev limiter, the replacement part number 4010354 has 3 wires, 3 of the wires color on the 5 wire match the 3 wire module, this is the only speed limiter available is the three wire any suggestions on how to wire the new limiter the old limiter two extra wires are gray orange and brown white
The original part (4010195 was replaced with 4013255) and neither is available and was used on the following models:
  • 1999 SCRAMBLER 500 (A99BG50AA) - Electrical/Taillight
  • 2000 325 MAGNUM 4X4 HDS (A00CD32FA) - Electrical/Taillight A00cd32aa
  • 2000 325 MAGNUM 4X4 HDS II (A00CD32FB) - Electrical/Taillight A00cd32aa
  • 2000 MAGNUM 325 4X4 (A00CD32AA) - Electrical/Taillight
  • 2000 MAGNUM 325 4X4 (A00CD32CA) - Electrical/Taillight A00cd32aa
  • 2000 SCRAMBLER 500 (A00BG50AA) - Electrical/Taillight
  • 2001 325 MAGNUM 4X4 HDS (A01CD32FB) - Electrical/Taillight A01cd32aa
  • 2001 MAGNUM 325 4X4 (A01CD32AA) - Electrical/Taillight
  • 2001 MAGNUM 325 4X4 MOSE (A01CD32AB) - Electrical/Taillight A01cd32aa
  • 2001 SCRAMBLER 500 4X4 (A01BG50AA) - Electrical/Taillight
  • 2001 SCRAMBLER 500 4X4 (A01BG50AB) - Electrical/Taillight A01bg50aa
  • 2001 XPLORER 400 (A01CG38CA) - Electrical/Taillight
  • 2002 325 MAGNUM 4X4 HDS (A02CD32FB) - Electrical/Taillight A02cd32aa/Ab/Ac/Fb
  • 2002 MAGNUM 325 4X4 (A02CD32AA) - Electrical/Taillight /Ab/Ac/Fb
  • 2002 MAGNUM 325 4X4 (A02CD32AB) - Electrical/Taillight A02cd32aa/Ab/Ac/Fb
  • 2002 MAGNUM 325 4X4 FREEDOM (A02CD32AC) - Electrical/Taillight A02cd32aa/Ab/Ac/Fb
  • 2002 SCRAMBLER 500 4X4 (A02BG50AA) - Electrical/Taillight /Ac
  • 2002 SCRAMBLER 500 4X4 FREEDOM (A02BG50AC) - Electrical/Taillight A02bg50aa/Ac
  • 2002 XPLORER 400 (A02CG38CA) - Electrical/Taillight
  • 2003 SCRAMBLER 500 4X4 (A03BG50AA) - Electrical/Taillight
4010354 was replaced with 2205237 and was used on the following models:
  • 2003 MAGNUM 330 4X4 (A03CD32AA/AB/AC/FB) - Electrical/Taillight
  • 2004 MAGNUM 330 4X4 (A04CD32AA) - Electrical/Taillight /Ab/Ac/Fb
Here's how the 3 wire unit is wired:
142189
Yel/red is a connection to the alternator to determine engine speed
Blk is the ignition kill wire used to squelch spark to keep engine speed to a preset value
Gry/org is the speed override wire to prevent speed limiting
Here's the 5 wire unit:
142190
The red/wht wire is 12v from the chassis wiring and brn/wht is the switched ground wire for the =AWD coils in the front hubs.
Since you are installing on a 2 wheel drive model, you simply leaver the r/w and brn/wht wires disconnected - other than that, the two units function the same.
HI this is a 4 x 4 model
I'm confused - I looked up the part for the 2001 Magnum 325 4x4 and got part number 4010195 which superseded to 4013255 - then I looked up the part you said you got (4010354) and found it was superseded to 2205237. I do not have the parts in hand and have no clue as to how many or what color of wires are on them.
The 3 wire unit is for the 2x4 - the 5 wire unit is for the 4x4 model - plugging the 3 wire unit in will provide speed limiting in in reverse and can be overridden with the button, but you will not have AWD in reverse.
the 2205237 is a 3 wire module just like the others there are no 5 wire module listed, the 2 left over wires are brn/white and gray/ orange also the 5 wire module has a LR 83-3 on it and a 410195 on it the 3 wire module i have is 4010354 it has yellow/red, black, and red/ white ????????
