1 - 2 of 2 Posts
C
Guest
i have a 2001 magnum 500 4x4 with allot of movement in the rear swing arm bushings, i took off the rubber caps and there is a large nut with a square center hole, i am guessing that you loosen the large nut and adjust the inside piece with the end of a half inch ratchet, and then retighten the nut. Or does it work some other way, first hand knowledge is best.
1 - 2 of 2 Posts
