The thing had been running good but the ignition switch would stay over and keep trying to start after it already was and when you cut it off it would keep running so had to wiggle it both times to work. Then all the lights went out on the speedo/neutral. Finally today it won't start at all. It will pull start but doesn't even make a noise when using the key. Every once in awhile it'll make a click at the solenoid and saw a spark one time but then can turn it another 50 times and nothing. The battery is good and tried the screwdriver across the solenoid but nothing. I'm guessing something in the ignition since lights went out first 2 weeks ago and now this but any suggestions would be greatly appreciated. Thanks.... Nevermind got it but still no lights except reverse
