1 - 2 of 2 Posts
Hi All, just joined from New Zealand. Got given the above model. Slowly getting my head around it. ( No expertise but can work most things out with some help) Picked up a Clymer manual which is as clear as mud. Anyway my first question is regarding the fluid debate. Been looking at posts all over and more confused than when i started. I am in the process of changing all the fluids but getting stuck on the Demand Drive, AGL and Angle Drive fluids as far as what to put where? Anybody perhaps simply this for me and perhaps some help locating the drain and filler points. I have sorted the engine oil, rear diff looks obvious, front not sure.
Appreciate the help.
As to what is called for and where - me? I use ATF in the hubs, transmission and final drives, but that's me - don't follow my lead unless you are comfortable with it.
I can email you the Polaris service manual if you want it. I just need an email address.
141714
1 - 2 of 2 Posts
