I take it there is no adjustment on the rear drive chains. Do you just replace them and are there any special tools required
Adjusting drive chains
you can adjust the chains by looseing the 2 bolts on the back of the swing arm. This will allow you to turn the large nut looking part of the axle. the avle is a cocentric so turning it one direction will tighten and the the will loosen the chain hope that helps jay
