Just bought an 01 scrambler. The stator has a green center tap for the cdi charge coils but the cdi has no connection for the green wire. It is wired to a toggle switch and back to the black wire on cdi. Will start with toggle switch open but must be closed to run or all it does is idle, anything more and it backfires. After a couple days it stopped running. Starts but as soon as you flip the switch it dies. Does anyone know if the charge voltage is different for the two different cdi boxes? Seems the center tap on stator would be cutting voltage for some reason. Flipping that switch to run should be splitting the voltage. Stator still checks good so it must be the cdi is fried. Anyone else ever seen this trick?
