Needing rear wheel bearings that I can find at a local parts house... I've read that explorer or Kia bearings fit but a part number would make it a ton easier
take the old bearing to napa they will match it up....there is a thread on here that tells the bearing demensions...also i think if you look on ebay some there have the demensions of the bearing in the listing...
Found the bearing it's part number 510003 car quest 22.00 bux other auto parts wanted 48.00 each ... Measurements are 40mm x 74mm x 40mm
