My clutch was wore out both the spring and groove wore in the face, I bought a used drive clutch off of ebay from a trail boss 250, does anybody know if this clutch will work on my bike, trying to save a couple of bucks. Also does anybody know what the torque should be when reinstalling the center bolt?
that i do not know, all that i know is they are completely different part numbers. it may be just a differnt in the spring tension or something else that can be easlily changed, or it may be completely different sized. i was just running a part fitment search on the dealer site and crossing part numbers over. you are propbably going to have to tell them you situation, and see if they can answer, but the dealer themselves might need to contact polaris to have them tell the dealers what is different.
the OEM PN# for the drive clutch for your machine is 1321976
the OEM PN# for a 1998 TB drive clutch is 1322682
with those two numbers a dealer should be able to tell you, even if they gotta call polaris
