Replaced the main wire harness because the mice used the ATV for a hotel. Did some other splicing that was not part of the main wire harness. Starts right up and idles perfect. I did buy carb kit but haven't installed it because it idles so good. Maybe that is my error.
I put Sea Foam in the tank with new gas but it did sit idle for several months between rides.
On the first test ride it seemed to have almost original power for first 15 minutes then lost power. Now it still idles great but when I give it throttle it seems to be missing like when in reverse before pressing yellow bypass button. The button doesn't help.
I installed new CDI module but didn't help.
I bought the ATV new and is hardly used.
Any ideas? Should I install that carb kit and clean that thing out
Thanks for any help or advice.
Check the intake for additional mice hotel.
