Hey all,
I recently got a 2001 Sportsman 500 HO and quickly realized that the front left wheel does not engage in AWD.
I've scoured the forum and have tested all electrical, replaced the fluid, inspected the hilliard clutch, and replaced a bent armature plate.
At this point, I suspect the problem is with either the coil or the clutch.
With the new armature plate, the coil's magnatism is much stronger than it was with the bent one, but I'm still able to pry it off with my fingers. It's not easy, but the fact that I can at all has me concerned. Should I be able to do this with a good coil?
Regarding the clutch, I did clean and inspect it per the service manual and the rollers definitely move more freely now, but I'm wondering if the splined nut in the center may be worn on the outer faces just enough to the point that it's not engaging the clutch rollers enough or at all.
So to sum it up:
1. Should I be able to pull a properly magnetized armature plate off the coil with my hands?
2. Assuming yes to the above, does my theory about the clutch hold water?
Thanks!
So to sum it up:
Thanks!
