1 - 14 of 14 Posts
speedo and 4x4 dont work i read up and am convinced its just the spedo that needs to be replaced can you guys give me any imput on what years will work or if i can put a newer model in and change the wires around?
i have a 2001 500 HO title says 2000 but its a 2001 model for parts
Welcome to the board!
Year Product Model Assembly
2002 ATV SPORTSMAN 400 HANDLEBAR AND HEADLIGHT POD - A02CH42AA
2002 ATV SPORTSMAN 500 ALL OPTIONS HANDLEBAR AND HEADLIGHT POD - A02CH50 ALL OPTIONS
2002 ATV SPORTSMAN 6X6 HANDLEBAR and HEADLIGHT POD - A02CL50AA/DA
2002 ATV INT'L BIG BOSS 6X6 HANDLEBAR and HEADLIGHT POD - A02CL50AA/DA
2001 ATV MAGNUM 500 HANDLEBAR and HEADLIGHT POD - A01CD50AA
2001 ATV 500 MAGNUM 500 HDS HANDLEBAR and HEADLIGHT POD - A01CD50AA
2001 ATV SPORTSMAN 400 HANDLEBAR and HEADLIGHT POD - A01CH42AA
2001 ATV SPORTSMAN 500 HO HANDLEBAR and HEADLIGHT POD - A01CH50AA
2001 ATV SPORTSMAN 500 DUSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA
2001 ATV SPORTSMAN 500 RSE HO HANDLEBAR and HEADLIGHT POD - A01CH50AA
2001 ATV WORKER 500 HANDLEBAR and HEADLIGHT POD - A01CH50AA
2001 ATV SPORTSMAN 6X6 HANDLEBAR and HEADLIGHT POD - A01CL50AA
2001 ATV INT'L BIG BOSS 6X6
Does the speedo light up at all? Their was a topic that a guy took his speedo apart and fixed it for 50 dollars.
nothing completely dead no light nothing but machine rides fine just no speedo or 4x4 my machince was made in 2000 but it is a 500 ho and 2001 model
If it doesn't light up at all you may have a wiring issue. There is a trouble shooting chart in the manual for checking that. Its too large to post here
I had a speedo issue on my 2001 also, I can't remember if I had a dash light on or not ,but my speedo worked after I replaced the hall effect sensor (speedo sensor) I don't think my 4x4 worked till I fixed that either....
it may be more of a power issue to the speedo...you need to meter out the pins on the plug see if there is power...there is a link here some where to down load service manuals....
On one atv I worked on I did the speedo bypass so that the 4x4 would work. The guy didnt want to spend the money to buy another speedo. I found out how to do that by searching this forum and found it. I posted in it. I think it was last year between April and November. I printed it off but it is at home. If you cant find it send me a PM and i will let you know.
Polaris Speedo Troubleshooting
Pull the 6 prong plug and test for 12 volts between ((A) Red/White +) and ((B) Brown -) on the plug not the speedometer, when the key is on.
If you see 12 to 13 volts with your meter do the same test with a small 12 volt light. If the light works, it is probably the speedometer.
If you do not have 12 volts between ((A) Red/White +) and ((B) Brown -) on the plug when the key is on, the speedometer may be OK and
you have a wiring problem elsewhere.
The brown/white wire (wire E) on the speedometer is where the AWD system gets the ground to make it work. 12 volts on this wire would be normal with the AWD system on and the 6 prong plug removed.
this info was from another site....
Discussion Starter · #12 ·
got the 4 wheel drive fixed and works without the override button in reverse as fast as i want to go thanks for all the help guys
What did you do to fix the problem so others can have some guidance.
1 - 14 of 14 Posts
