I have been using the Polaris oil change kit but was wondering if anyone used other aftermarket filters and oil? and what do you use?
Thanks!
Nick :veryhappy:
K&N oil filters and mobile 1 full synthetic 0-40 or 5-50 here on my 2012 500&800
Sent from my MB886 using Tapatalk 2
What k&n filter or wix part # does it use? And it's still 2 quarts of oil right?
Here, I just made this. And just added your answer to it.
http://www.machinecheatsheet.com/2001-polaris-sportsman-500/
And yes, 2 qts should be good. Depends on whether it get all of the oil out of the crankcase side. If you go by the dipstick, which isn't a bad way to go, somethings it's a little more, sometimes less for whatever reason. I'd just get 2 qts.
WIx # 51358 Fram # 6607, Still holds 2 Qts, use a quality full synthetic, I use Castrol Edge 5-30 in the motor and tranny has worked fine in probably 20 different machines for several years
