Unable to shift to forward/nuetral/rev. with engine running. Shifts fine when motor is turned off. What is the problem?
Wierd! Welcome to the board!
my 00 sportsman man would grind if i was moving. i did have issues with it not shifting becuse of the long linkages. check the linkage from the shift leaver to the tranny. just a thought. not saying im right.
my newer one had issues with it not shifting when on. that was a high rmp issue. but was fixed with the carb adjustment screw.
