Hello everyone!!
I am new to this site and was wondering if anyone could help me out with the replacement of the starter on my machine. How many bolts there is to taking it off? Tips? Best way to put it back on? Anything will help and will be greatly appreciated!!
two mounting bolts and also the positve cable from the start cylonid. disconnect your negative battery cable so that you do not run the risk of power getting through the cylonid to that positive cable and possibly welding itself to your frame. its a tight fit to get them in and out. pay attention when you pull it out and put it back in the exact same way
Add Part# Description Quantity
1 3084981 MOTOR, STARTING * (Incl. 2-6,8-12) 1 Usage
2 3084982 WASHER SET 1 Usage
3 3085353 ARMATURE ASM. 1 Usage
4 3084406 BRUSH,COMPL.2-POLE * 1 Usage
5 3083649 NUT, FLANGE(10) 2 Usage
6 3084408 O-RING 3 Usage
7 3082038 BOLT&WASHER ASM. 2 Usage
8 3085034 COVER,REAR,STARTER(MAGNUM) 1 Usage
9 3085033 COVER,FRT,STARTER(MAGNUM) * (Incl. 10) 1 Usage
10 3240114 O-RING 1 Usage
11 3084983 BOLT ASM, SET (Incl. 6) 2 Usage
12 3084405 RING, RUBBER 2 Usage
13 3083737 WASHER, GEARSHAFT Substituted by 7555908 1 Usage
14 3084412 CLIP 1 Usage
15 3084411 SPRING, WEIGHT 1 Usage
16 3084410 SPRING, RETURN 1 Usage
17 3084409 CLIP 1 Usage
18 3087030 ASM-GEAR SHAFT * (Incl. 13-17) 1 Usage
And welcome to the board!
Hello everyone!!
Pod light is just dark now. It hits the rack extension so the led bar is better.
