I have a 2001 sportsman 6x6. I am getting gas in the crankcase, any suggestion greatly appreciated. Thanks, Gepp
Have you checked the airbox for gas too? If the float bowl vent is plugged (or the tube leading downward from it) and the needle and seat are leaking, gas will overflow up through the carb throat either forward to the engine intake or rearward to the airbox, depending on the angle the carb sits at. Gas flowing forward into the intake will flood the engine (and can hydrolock it in extreme cases) while gas flowing rearward will flood the airbox. Depending on where the engine breather tube enters the airbox, gas could flow from a flooded airbox through the breather tube to the crankcase. Just a couple of thoughts... Good luck. - MarkC
7627, thanks for the instant reply, i just pulled the carb and i would like to rebuild it. Any suggestions where to get a kit? Also would like to know how to disconect the choke cable from the carb. I figured out the throttle allright but the choke has me stymied. Thanks again for all the great advice. Gepp
Hmmm. The choke should be the easy one. The cable end has a hex head that just threads into the hole in the carb. The end of the cable has a spring loaded metal cup with a rubber seat that should just come out with the cable. It isn't connected to anything inside the carb. I've been buying carb kits from a couple of eBay vendors and always keep one on hand in case I need it. - MarkC
marc, i have the carb off but do not know what model it is? its a mikuni 5ol10a e071 Engine is a 499cc, engine # is eh50ple-06 appreciate any help. Gepp
talk to fix my toys asponsor here, I believe he has a kit for your carb
gepp, you can easily look up OEM parts on this site: Polaris Parts, Polaris Snowmobile Parts, Polaris ATV Parts, Polaris Ranger Parts, Polaris Accessories at wholesale prices
Just use the pull down menus for the year, model and view you want. As for carb parts, dealers sell individual parts so you might not need a complete kit. Getting a complete kit is easy though, either at the dealer or from a vendor. Most of the 500's take the same one. You can easily find one on eBay by using your year model, 500, and carb kit as key words. There are some vendors that support this forum that are eBay vendors too. Good luck. - MarkC
