okay, Engine runs great except when I turn left at low engine RPM. When it starts to stall it is like the engine idle screw is turned down. if I give it alittle throttle it doesn't die.
The throttle cable may be getting pulled see if it is binding somewhere. It could be slacking off too much and letting the idle go down to low to run?
Ill take a look at it tomorrow, I am not sure how that would happen. but ill keep an open mind and check it out.
My buddies 800x2 did that after we replaced the throttle cable we had to use hose clamps on frame instead of zip ties to keep cable from moving when turning. His was dangerous when making a right turn it would throttle up not good when trail riding with a group almost rear ended someone a few times. Good luck make sure what ever you use to attach to rail it secures tight!
