The oil coolant fan on my four wheeler won't turn on anymore. I want to check all the fuses before I go buying a new fan, the only problem is I'm not sure where they are. Where are the fuses for my oil coolant fan? And if those are good is it difficult to replace the fan?
There is only one circuit breaker on the entire machine, its sealed in a bag back behind the starter solenoid. If you have electrical power for lights and the starter, than its good. Remove the front rack and plasctic and unplug the temp sensor on top of the oil cooler, the fan should come on. If it doesn't, unplug the fan and see if it has power. Should have 12v on the red and white wire, and a ground on the orange wire with the key on and the temp sensor unplugged. The power is always there, and the ground is switched on and off to control the fan.
