A bit of a long story.. Last year the quad started to backfire randomly when the lights were on.. Thanks to this forum I found that the circuit breakers in the sealed pouches were corroded so I changed them and that solved the problem. After fixing that problem, a branch went through the rad so I replaced it with a new one. Not sure if there was an air lock in the lines but since it has been drawing from the reservoir and I have to top it off frequently. I have yet to see coolant anywhere and assumed that it was filling the lines and would eventually stay at the full level. Moving forward into winter, as I am in Canada and we've had a cold one, I hadn't been using the quad very much. I had left the petcock on and one day noticed a strong smell of gas coming from the garage. I checked the dip stick and the oil was milky and smelled of gas. From there I assumed that the float was stuck and gas had drained into the oil? I flushed 3 times and changed the filter and all seemed fine for a couple of weeks although the coolant issue stayed the same. The oil is now milky again and smells of fuel although the fumes do not fill the garage. My thoughts are possibly; water pump, head gasket, or carburetor issues? Maybe the backfiring from the circuit breakers is the cause and it's the head gasket? Also, there is no white smoke coming from the exhaust and I have been turning the petcock to the off position and letting the quad run to try and eliminate any gas issues if the float is stuck...?
Any feedback would be appreciated because right now I'm trying to figure out the best starting point.
Thanks!
Thanks!
