1 - 11 of 11 Posts
well i have been sold a 2x4 2002 trailboss.
the frame model number is w937527....Vin 2110307
so i have worked out which parts are missing and it seems to match up with a 250 trailboss 1992 production.Is this right as I am needing to order the right bits for it and I dont have the bits to reorder from.
thanks....I think I may send the doris to go visit the seller......:twak:
Did it not have a title with it? What year was it titled as?
Which matches the model W"93"7527 by the way.
right i have found out with thanks which quad i now have,also found the original supplier here in the uk.
just got to check engine numbers then i can order the correct recoil starter for it..
i had pretty much worked out which part i had but it was not 2002 so now i know its 1993!!
so is the engine a good one or shall i fit a diesel to it?
What are planning to do with the quad?
Discussion Starter #8
well the compression is low and its well worn in most places,missing pull recoil case and its a bit tatty...
i want to use it for sheep work.I had it running with the drill on the crank shaft and its quite fast also the gears work.
it was very cheap.
At the least do a top end with a Wiseco piston. I think trying to go diesel would cost more than it would be worth in the long run.
Discussion Starter #10
well that was my thought,it will be fine for getting the sheep in.I looked at some cheap chinese quads but found the 1 I have for just a few 000 so if i get it running I will keep it or sell it depending.
the decent condition 4x4 quads are real expensive and i have a 4x4 so just cant justify the spend in our current climate so i have gone for the scrap quad rebuild so i get better for less.....
stuff in the uk is stupid expensive
Discussion Starter #11
well got the parts for $165 delivered so see how it goes with the pull start,i may set up the electric start too..:veryhappy:
1 - 11 of 11 Posts
