1 - 2 of 2 Posts
I’ve got a 2002 Ranger. It starts, but as soon as you put it in gear it dies. If you start it with the choke and put it in gear it will continue to run. And you can even drive it. As soon as you turn the choke off it dies. Any ideas?
I could not find a 2002 Ranger - Polaris website lists 1999, Series 10, Series 11 the 2008 and up
At any rate, when they won't run unless the choke is on it usually indicates the carb needs cleaned - sometimes it's just because there is a low fuel level in the float bowl
1 - 2 of 2 Posts
