I recently bought a 2002 400 2x4, very clean bike and a good running machine, however the seller warned me that it would overheat after 15-20 mins of riding, cools down and restarts. given the overall condition i bought it anyway figuring it would be a simple fix.
took it out this weekend expecting the problem to arise, which it did, bike through the temp light and it died like clockwork after about 15 minutes. i pulled the radiator cap and the coolant was warm but by no means hot, and i have not been able to get the bike to restart. i suspect there is a couple issues going on at this point but thought i would call on someone here for some additional insight before i tear into it, not much experience with the two strokes.
Has brand new battery, and plug, prior to the ride. thanks in advance everyone
First off, the battery is not part of the ignition system - the ignition is magneto - consists of CDI charging coil, pulse coil, CDI unit, coil, spark plug cap, spark plug and the associated wiring.
I suspect an electrical component as cause of the problem - overheating and losing spark
To start isolating the problem, disconnect the black (kill wire) at the CDI unit - this will eliminate all the switches and the reverse speed limiter as the culprit if it dies - if it does not die, then you have to determine what is causing the killing of spark - if it dies with the black wire unplugged, then it's a matter of finding which component of the ignition system is causing the problem.
So it will (potentially) start with the black CDI wire disconnected? it won't start right now
With the black wire disconnected you can't turn it off - have to ground the black wire on the CDI box to kill the spark.
turns out the boot for the plug was damaged so starting issue has been resolved, any insight on the overheating issue?
