I have an 02 sportsman 500ho I bought for my son. We rebuilt everything it seems on it and today was his first ride. I noticed the antifreeze level was down so I topped it up. Upon my sons return from his day riding I noticed the reservoir was empty again. I started looking for leaks hoping that it isn't a head gasket when I seen a wet spot on the bottom of the motor right below the water pump. The rest of the motor was dry except for this one spot which was right above were the antifreeze was dripping. I found what looks like a small plug possibly under the water pump which is leaking. The previous owner obviously knew about the leak because it was plugged with silicone. My question is what exactly is the small whole/plug that is in question. Is it a drain plug by chance? I'm going to attach a picture but I'm not sure if it will be noticeable(the leak is coming from just below the arrow). It is right above the u-joint on the transmission side of the prop shaft and below the water pump. Is this something that can be turned out and re-installed with pipe sealant or is the case possibly cracked.
Any help would be appreciated.
