Front left AWD was not working. Disassembled and found the magnet very very weak. Ordered and installed new magnet. Problem solved. NOPE! The magnet was a problem but not THE problem. Assembled together and AWD works on left wheel but I can stop the wheel with 2 fingers.
Pre-load is correct. Bearings are all good. Assembled in correct order. Has anyone seen the cam (part # 3250030) wear down so that it is barely lifting the rollers up.
Do I need to replace the cam?
Thank you for any help you can give.
