Hello,
I'm new to this forum. Will be purchasing a 2002 Sportsman 500 HO over the weekend. Want to add a winch and snow plow. Neighbor can fabricate something from scratch. Anyone have patterns, pictures or suggestions on this. Could be a purchase if needed.
Also, has a clutch problem. Stays engaged. I read somewhere it might be "out of balance" perhaps? Unsure.
Any idea what is involved and approx cost of repair?
Thanks. Dave
Welcome to the board!:med:
If its an ebs clutch, ebs washers are bad, need replaces or you have an alighnment problem, need special tools to remove and repair primary clutch
Also could be the belt if they added an aftermarket one that's out of spec. Could also be the flyweights, if they don't return to where they belong it can keep the belt engaged too. Only way to tell is to take it apart.
