Hello everybody, I got a weird one, I had my engine lock up at just above idle and found it to be the flywheel magnets came apart and everything got destroyed. I installed a new stator coil assy. and a good used flywheel I finally found. I checked to make sure that nothing was touching, I turned the engine over by hand many times to make sure nothing was rubbing, I even pulled the flywheel off again to check if their were any marks on the magnets or the flywheel. Everything was ok. I started it ran for a few seconds and died, tried to start it again, it got stuck like if the timing was too advanced, tried again, locked up, %#[email protected] pulled the flywheel, Magnets destroyed. Checked for play on the crank shaft with a pipe, none. I am stumped.... Anybody got any Ideas? Can I put a different year flywheel and ignition system besides the expensive Kokusan kit (2202602)?
Thanks in advance
Welcome to the board!
