Hi everyone. I have a 2002 Sportsman 700. It's a carbureted model. It's been sitting a couple years. I try to start about a month ago, it started once. Then, no spark on the spark plug since then. I replaced spark plugs, no luck. Power comes to ignition module/coil unit. I thought ignition module/coil unit was bad, and bought a new one (it was expensive) still no luck. If anybody has idea what is wrong with this and share your thought, it will be greatly appreciate.
I have same machine, but have not had this issue... had a few others I could help ya with... good luck man
Welcome to the board!:med:
The Ducati systems in those machines go bad, they sell a kit, Kokusan # 2202602 that replaces everything, their not cheap ,,$475 or so but thats the fix, do a search on Ignition systems, lots of posts, on it.
