Hello, I have a 2002 Sportsman 700 that I am trying to replace the shift shaft and the bellcrank shift drum on but they don’t seem to fit together like I thought they would. Does this need to be pressed in?
154462
Are you sure you have the timing correct? There is a flat spot on both pieces that need to be lined up?
Discussion Starter · #4 ·
I was wondering if they would press together as you tighten the nut but I didn’t want to take the chance and be wrong so here I am….
