I just bought a 2002 Xpedition 425 that is stuck in 3rd gear. The guy said he just changed all the fluids and shortly thereafter it got stuck in 3rd. I've done some reading and found that the tranny is sensitive to what oil you put in it. I'm hoping I can fiddle with it enough to get it to break free after I fully thaw the machine out and then put the proper spec oil back in. If that doesn't work, what else can I do before tearing it down completely? FYI, I have no issue tearing it down as I half expect to end up going that route, but I'm hoping someone might have some good tips to try first, thanks
