Well I have an update for anyone that may have been experiencing the same problem.....Finally after having several people with good intentions look at it, I brought it to a Polaris dealer and let a licensed tech look at it. He discovered the coil and spark plug boot put on by one guy was not correct as it had a resistor in it which it can not have. Another "good intentioned mate" had put a second battery on to give it more amperage to turn it over to start.....wasn't hooked up properly. Also found a short on the battery wire. The Polaris Tech actually found a few things wrong. He also discovered the left handlebar controls (kill switch,headlights etc) was damaged and when he removed it, found several wires corroded and green causing a short. So replaced the handlebar switch, removed the two batteries, installed one good one and fixed the short at the battery. Although the battery tested at 12 volts, as soon as you used the key it dropped to 2 volts and would not produce enough power to spark. But when I used the pull chord it was able to maintain 12 volts as it wasn't using the electric starter....
I think I got what he told me right. Hoping this may help someone else out experiencing similar problems. I guess in the end I learned a valuable lesson in taking my ATV to a trained and experienced factory tech first and not letting someone "experiment" on my machine. In the end I paid dealer price/cost for repairs but ALSO paid for the costs of the experiments by the guys with good intentions.....lesson learned. Thanks Go Performance in Dorchester Ontario!!
