New member here... I'm trying to tighten my chains. I loosen the bolts on the eccentric housing, put a pin through the sprocket to the eccentric housing, rotate the axle back and all I get is a broken pin... the eccentric housing seems to be stuck. Anybody with any ideas?
polman 500;
You are the best. Tightened and tested. Thanks! I'll likely need more help. Have a great week.
:beerchug:
