there looks to be only 2 20amp circuit breakers one appears to be by the starter solinoid and the other seams to run the fan.
thanks would u have any idea why after cleaning carb, it will not crank until i pull off main gas line to carb, it will crank idles good runs gas out of bowl and cuts off, if i try to hook line back up it cuts off. i took off back of carb where air filter is and the gas is blowing towards back instead of front towards cylinders, never seen this before in my life.
