I need some help, i got the carb off but the only thing i haven't is the throttle cable and the choke cable. Unsure of how to get it off. I need a visual if possible.
16mm wrench to unscrew the choke cable and take the side cover of the carb where the throttle cable goes in, use a small screwdriver to slip the cable out of the groove and pop the brass piece out of its hole. Be careful not to lose the brass piece. May have to loosen up all the throttle cable slack to get it out. It's easy once you see how it works.
Welcome to the board!:med:
